panofish
- Mar 8, 2012
- 57
- 3
I am having a tough time finding a way to get good accuracy for my hollow chisel mortiser.
It has a B16 plain bearing chuck... which is showing inconsistency when I chuck the drill bit for the hollow mortise chisel. Sometimes it chucks the bit ok... other times the bit is chuck way off center and the bit wobbles badly. I would like to avoid the trial and error approach to getting the bit well centered into the chuck.
I have looked and it is very difficult to find a B16 ball bearing keyed chuck in the USA. They are somewhat common in Europe, but difficult or very expensive to purchase.
Any suggestions? I have even contemplated the crazy idea of seeing if there is a way to mount a collet fixture onto the B16 tapered shaft from the motor, since my bits are the same size shaft.
I realize that a hollow chisel mortiser is not a milling machine, but I need better accuracy for this chuck.
What do you guys recommend I try, so that I can get consistent centering of my drill bits in the mortiser?
