Hi Dave, mate please jump into this thread whenever you feel you wish.. and take it into any directions you wish.... ;D
The input is ALWAYS welcome.
I used timber stays in the drag and a casting board under the cope... I think I eluded to the fact that there is the correct way and then the way I used .. :big: Ive never cast a unit this size in a closed mold before (open mold yes..) and doubt that I ever will again... but, it did work after a lot of mucking around....
Howdy Tel, I guess the cement would make the sand a 1 use event, would be worth it though.. and for the record...I used YOUR clay in this one... thanks again mate.... and THAT beer would definatley not be good for this... it aint good fer nuffin.... :-
Today I used the flycutter to flatten and pretty the working surfaces... firstly the back of the plate....
And the mounting surface....
I added a little putty to a couple of spots.. those areas Ive already discussed as not pleasing me greatly....
and roughly how it will sit... boiler will be up so its top is just under the crank centre line.
No real inclusions to speak of, a good solid cast... machining them up is alweays the test.. they all look good until you cut open the voids etc..
Cheers all...
Rob T
