Well, I promised (threatened?) that I would start a WIP for my probably long-running design process for a scale Pratt & Whitney R-4360.
For anyone curious, the R-4360 is considered the largest piston engine to ever go into production for airplanes. It was used on a variety of aircraft at and after the end of World War II, and while thousands were manufactured, most were scrapped when the military no longer needed them due to the introduction of the jet age. Few remain, and fewer still are still flying. Most are in museums as static displays, many were even cut away to show the interior workings.
In the past couple of years I gained a sort of passionate love for this 28 cylinder radial engine that my girlfriend is probably a little jealous of. I have done a lot of research on the engine, and am always doing more. I feel the best way to show this beast a proper respect is to try and develop a working scale model.
Countless design decisions will be forthcoming, and I welcome input from all corners of the forum on anything that sounds or looks questionable. While I intend to build this behemoth of a model, I currently have no shop, no machines, and very rusty skills. If something looks like it will be impossible to machine, please don't hesitate to speak up.
The full-scale R-4360 sports some utterly astounding statistics. 4,363 cubic inches of displacement, 28 cylinders arranged in 4 rows of 7 cylinders, with 4 magnetos driving them. It 'sipped' upwards of 100 gallons of 108 octane fuel an hour (try that with today's prices!) all metered from a single pressure carburetor. Each cylinder sported a 5.75 inch bore with a 6 inch stroke, giving a 6.7:1 compression ratio and fired two spark plugs to ensure the cavernous compression chamber ignited evenly and fully. Intake ports were mounted on the top of the chamber, with exhaust out the side (analysis done since have suggested it would have been far more efficient to switch these two, and would have solved some of the intricate heat problems they had). This entire machine was air-cooled, requiring an astonishing amount of air to flow through the cooling fins, and indeed a lot of designs were tried to get the optimal cooling. The 3000-3500 horses were caged in a package that measured 55 inches in diameter and 96.5 inches long, weighing 3,870 pounds dry.
In military applications, the Wasp Major as it was known, was used in a variety of aircraft, from experimental to production. A list of aircraft that used this engine can be found on the following wikipedia article: http://en.wikipedia.org/wiki/Pratt_%26_Whitney_R-4360_Wasp_Major
Perhaps most notably was the F2G "Super" Corsair (Not the much more popular F4U Corsair, but very similar). Postwar, Several F2G's were converted into racers that dominated the air races until a tragic accident shut down the Unlimited Class until the 1960's. Since then, one Super Corsair named the Dreadnought took away numerous finishes, until it crashed in the mid 1980's. I believe Dreadnought is nearing rebuild, but that information may be inaccurate.
My goals with this design are to create a 1/6th scale version of the Wasp Major, though many design concessions will have to be made to ensure that it will be a running model. I will attempt to document the process of development, and as I am using a CAD program it should be easy for me to go back and make adjustments as required (provided I follow proper CAD procedures, something I often fail to do)
Again, if anyone sees anything questionable, has input, or any questions in general, please don't hesitate to jump in and help me. I apologize for this being a CAD work (for now!) and not a real machine, but some time down the road I will start another WIP when I have sufficient tools and skills to give the real thing a try.
- Ryan
- Ryan
