#1 Heres a few pictures of the parts I made over the past few days. The picture below shows an aluminum block being planned down to dimension. I used a different approach and did most of the machine work, for both rods, on one block of material.
#2 I center drilled, tap drilled, clearance drilled, and tapped both piston rod ends on one block from both sides. These will become the rod cap ends.
#3 I numbered both sides with a metal stamp, in two areas that will become the crank end of the piston rods.
#4 The cap end was cut off as one piece in the band-saw, then the saw-cut cap end and rod end were both milled flat.
#5 With the cap end installed, the block was split lengthwise, in the band-saw.
#6 The cut sides were milled flat and down to the proper dimension.
#7 All four sides of the piston rods were milled down to clear the piston and cylinder skirts. The rod ends will be left plain since they will be inside the crankcase and not visible. The picture shows them in a rough state, the edges will be rounded and the machine marks will be removed. The pistons were turned down from brass bar stock, stepped out using two different sized end mills and then cut-off. They were cross drilled centrally using a milling machine.
#8 The side covers were turned on a lathe. They were drilled in the mill, along with the crank case block that was tapped. The precise movements of the calibrated hand wheels were used to locate them. This side cover was machined flat to create the area for the gear train.
#9 The flywheel side was machined with a bit of a sculptured look that blends into the longer bushing used on this side.
#10 The bronze bushings are used to center the crank shaft. On the flywheel side the bushing is 5/8 long, and on the gear side, that was milled down flat, its just under 1/2 long. I wanted to create as much of a support area as I could for the crank shaft since Im not using ball-bearings.
-MB
