Wow! You made quick work of that!
That throat plate looks great. What size torch did you use to anneal the plates?
Todd
Todd
Wow! You made quick work of that!That throat plate looks great. What size torch did you use to anneal the plates?
Todd
I have a very similar torch. I'm glad to hear that you are only annealing the areas to be worked. I thought I would need to anneal the whole sheet to prevent warping.
Todd
The boiler front end plate machining started with drilling holes for the firebox studs, the blower tube fitting, and starter holes for boring the firetub holes.
In the book, Kozo mounts the front plate (and later the firebox plates) to the lathe faceplate to cut the holes to size with a boring bit (drills this big would never give a clean round hole). However, this is another case where a little ingenuity was needed to do the operation on a small lathe. I could just get the front plate offset enough on the lathe, with the riser block in, but there is not enough clearance to do the same on the firebox plate. So, am doing those operations on the mill, which has a slightly longer reach, plus using the rotary table means the mill cutter only has to reach the inside edge of the hole, not the center. So, I screwed the plate to a piece of wood on the faceplate (same one used earlier to mill the formers), and milled the three firetube holes out to size.
Wondering if it would have made more sense to use a boring head instead of a rotary table and an endmill here...
Take a look at this page: https://www.flickr.com/photos/90015082@N00/sets/72157608204743742/page3/
Scroll down a little and you'll see how Greg set up the boiler of his A3 to drill and bore the holes.
Keep up the great work, and thanks for all the photos!
Todd
PS. I posted this before I saw what you just posted above. Looks Great!
I... One instant rivet. Square head, but since that will be on inside does not matter....
