Next step is done on the boiler former blocks - got them milled down to size. For the round ones, I screwed a sacrificial block to the faceplate, drilled for a bolt on the lathe to ensure the bolt was centered, and screwed that assembly onto my rotary table (which has a screw adapter for centering chucks on the table). Then I could bolt the round formers down and mill them to exact size (spiral mill leaves a finer cut on this wood than the lathe bit does, plus the odd shape ones later would not work on the lathe anyway).
![IMG_4690.JPG IMG_4690.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28297-f161efcdf5bc5048926a3bcecf931433.jpg)
Same was done for the smaller end formers.
![IMG_4691.JPG IMG_4691.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28298-38b4b1870c07ca5789072f98201a2064.jpg)
For the formers around the firebox, which have a circular end and a straight base, did the same thing but stopped turning the table where it met the straight sections (third photo).
![IMG_4692.JPG IMG_4692.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28299-339dab88228124ea88d9e1642ff2b332.jpg)
There are also a pair of formers for the forward end of the firebox area, which are just a rectangular section with an arc cut into the top. This needed a different holder, one with a tongue sticking out to bolt the former to (bolt holes needed to be right distance out to put the arc in correct place). I could not use a larger circle for this, since I dont have enough reach on the mill.
![IMG_4693.JPG IMG_4693.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28300-0c860b9669298f0d6b5b6a62762f23a8.jpg)
On the wider of the two, (fifth photo), there was not enough room to rotate it all the way past the cutter, so I did as much as I could on one side,
![IMG_4694.JPG IMG_4694.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28301-7ccc2c6715d3c625122ee4f154199ff0.jpg)
then finished it up on the other side of the column (did not move the former on its holder to ensure it stayed centered).
![IMG_4695.JPG IMG_4695.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28302-a3acf28c3276010a5ade487bc2dc5401.jpg)
With both of the throat formers cut, bolting the together shows the step formed - the arcs are different by the thickness of the copper. This will allow using a pipe section to finish hammering down the flange there - will all become clear when that piece is made. Kozo really thought these formers through, looks like a good sequence he has in the book.
![IMG_4697.JPG IMG_4697.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28303-c4e9a50001135843f1dd840eec9aa478.jpg)
At this point all the formers are cut, milled to shape, and drilled where needed. Still need to go back and round over the corners of the edges the copper will be hammered over - will use a small 1/4 round bit in the trim router for that.
![IMG_4698.JPG IMG_4698.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/28/28304-0310f9a5b2db0e2b96f64f859bbacd7b.jpg)
Once that step is done, will be time to start cutting copper sheet! Think I'm gonna cut each blank, and take some of the offcut scraps to experiment with the hammer (have wood and plastic head mallets for the forming)....
