Been short on shop time lately, starting to get back to normal now. Next thing up on the tender were the sandbox and ladder for the back end. The sandbox is a simple shape, just a large box with the center area cut out, but it is quite large. In the book he mentions that you can make it out of two blocks of brass, or anything else. I happened to have some aluminum bar the right size, so I used that. It was made in two halves, with the shape done on the mill while the blocks were clamped down on a piece of wood to protect the table.
After milling the outline, the two blocks were glued together with some JB Weld epoxy (a spacer block on the back side also straddles the joint to help hold it together. The lid plates on top were made out of brass.
A coat of paint, and the sandbox was done.
Next up was the ladder. The sides were bent from some square brass bar (heated with a torch and bent hot). Holes were drilled in the sides for the rungs. The rungs themselves were made frm brass rod, with the ends turned down with the parting tool (did the end, moved it out in the chuck, positioned the parting tool to proper length by counting turns on the lathe bed, and the other end turned in). This way the rungs self-spaced the sides for soldering.
With the rungs soldered on, and some crossbars at top/bottom to take bolts to hold it in place, the ladder was done.
I took the engine and tender down to the basement to get some more painting done the other day, and now that the paint has cured up it was time to get the lettering onto the tender. I had done some experiments with printing the text onto self-adhesive film to make stencils with, but that was a failure. So, went back to old standby of using dry transfer (rub on) letters. Woodland Scenics has a good font available in white letters, so got several sets of those (each page only has a few of some letters, so needed 4 pages altogether). To get a spacing guide, I set up a light box from my photography days and traced the lettering off onto a sheet of paper. Important thing was to get the spacing to look right, so the tracing mainly had the left/right edges with the middle of the letter just sketched in. When I had a set of tracings that looked good, they were cut out and taped just below where the actual letters would go, and I started laying down the real letters. If you have never used them, quick description: the letters are printed onto the back of a sheet of plastic - you line up the letter you want on the surface you want it on, and rub over the top of the plastic with a burnisher or (what I like to use) a dull pencil (do kids today know what a pencil is?) That rubbing sticks the letter to your work, and releases it from the plastic sheet. After they are all down, you go back and rub it some more through another sheet that looks like heavy tracing paper to make sure it is well stuck down. If you want you can clear coat over them (I have done that on boat models, for this project I did not).
Next photo shows the first panel with all the letters on, ready to bolt onto the tender (the plate has threaded studs in the corners that go through the tender walls and bolt on the inside).
Last photo shows the tender just about done, still needs the white strip along the edge of the floor - next up will be the lights for back of tender and front of the boiler. Really looking like a train now - amazing how different it looks with the tender made. For those following along with Kozo's book, I have skipped over all the remaining plumbing steps - will go back to that stuff last.
