Time to get caught up a bit - not too much time in the shop this week due to some minor family medical issues. Given the ongoing needs there, I will not be making it to Cabin Fever or Names this year
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
, but am planning on bringing the engine next year.
I did get the tender frame parts made - these bars line the upper and lower edges of the outer skin of the tender, holding them to the baseplate and providing a support for the tank lid. The book/plans give locations and sizes for cutouts at the corner areas where the bars are taken down thin enough to bend to a tight radius. After laying them out on the bars, and end mill was used to eat away the notches...
![IMG_6100.JPG IMG_6100.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31761-786e96d7cfbab8dcaa2a85d6388b494b.jpg)
Second photo shows the bars for the lower edge of the coal bunker recess in the water tank. The upper one has been bent to shape, the lower is ready to go.
![IMG_6101.JPG IMG_6101.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31762-25b2a53f1de58b02464b1d140efccb2f.jpg)
Third photo shows the two bars bent to shape.
![IMG_6102.JPG IMG_6102.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31763-d2be18eb58b812601283f50cccec72ff.jpg)
After this, the same was done for the longer bars that go around the water tank sides/back, plus the other bars that go around the top of the tank.
![IMG_6106.JPG IMG_6106.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31764-3a1d28c3d12302b5992ac688fd239e4a.jpg)
Next step was to make the tank side plates. They are cut from brass sheet stock (book calls for 1mm, I used nearest inch size). The tank also gets rectangular plates on the sides and back that double up the thickness. The corner areas plus the flat plates get embossed with dummy rivet heads. To make the rivet heads, the sheet is embossed from the back side with a center punch held in the drill press (NOT running, just pressing down), going into a recess in a backer block. To make the backer, I cut a row of hemispherical holes into the block with a small ball head bur. The holes were the same distance apart as the finished rivets will be, and the right distance from a fence block.
![IMG_6107.JPG IMG_6107.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31765-881b78cb2a0de5fddf61a848dd5f27d3.jpg)
To form the rivets, the tank side was held up against the fence, and the drill press quill pulled down to push the punch into the metal, deforming it into the hole in the backer block. Then the sheet was moved over so the newly formed head dropped into the next hole, and the process repeated. By having the holes act as an indexer, a row of evenly spaced rivet heads can be formed very quickly.
![IMG_6108.JPG IMG_6108.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31766-77cfdd7aa95c62c1a404a2f734aaa253.jpg)
Next photo shows a closeup of a row of the rivet heads embossed into the sheet.
![IMG_6109.JPG IMG_6109.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31767-ca08937d3580f3f980686928a8f32018.jpg)
Last photo shows the side plates with rivets formed around the edges, plus another pair of rows down the midlle (same process, fence farther from the holes). After all the rivet heads were done, the side sheets were ready to bend to match the frame pieces....
![IMG_6110.JPG IMG_6110.JPG](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/31/31768-b70ac06d34e760c1d40c8047b1cca066.jpg)
