The cab roof support (used to hold it open to make access to valves/gauges easy) started with making a pair of hinge ends very simaler to the roof hinges. Then, took a strip of brass for the support itself and drilled one end for the pivot, and a series of holes at the other end for the slot. The slot was then cut out with a jewelers saw and filed smooth.
Next, needed to make the little handwheel to tighten the bolt that rides in the slot. In the book, Kozo uses a cross-rod arrangement like you would have on a bench vise. I decided to use a handwheel instead since it will blend in with the handwheels on the valves better, and be just as functional (plus easier for fat fingers to turn). Started with a bit of brass rod, drilled/tapped the center hole on the lathe, and then went to the rotary table on the mill to drill the series of holes around the edge. First spot drilled to locate the holes,
then drilled them out to size every 60 degrees.
After that, moved the table over a bit and used an end mill to make the recesses in the edge of the wheel. I plunge cut each one, so that I did not have to worry about getting the distance in from the edge the same on each one.
Moved back over to the lathe, filed the edges round, and parted off the wheels - had enough depth for two of them, sure the second one will get used somewhere...
With the wheels parted off, soldered in a short length of threaded rod (cut from socket bolts) in the center.
With all the parts made, they were assembled onto the cab and roof.
Next up will be the end plates for the engine cover, hand rails, and steps, which will complete the cab....
