- Mar 9, 2010
- 597
- 704
First up, got the panel that goes at the cab end of the engine cover made - simple sheet metal plate with some slots and holes in it.
Then started on the handrails for the cab - drilled a set of holes in a rectangle of sheet brass,
and silver soldered in the bent brass rod. Keeping them as a pair made them stand up, so it was easier to solder up.
Then, cut them apart and filed the plates down to shape with rounded corners.
Installed on the cab, gives it a nice finished look.
Next to the rails, in the inset panel, will be another place where the loco number will go (to match the one on the front end of the boiler). I have not cut them out yet, but have the numbers inkjet-printed on some transfer film and stuck on the brass sheet.
Got a start on the ladders that lead into the cab. Dug around in the scrap box again and found some brass the right thicknesses (the cab is using up a bunch of the offcuts). Hacksawed (hacksawned? hacksaweded? whatever...) them to rough size, then milled them straight and square to size.
Last photo shows the steps and risers ready to go. They will be screwed together and silver soldered up next time....
