Thanks Carl. Yeah - I love the mill ;D; still some issues to sort out on it though; I think the spindle bearings are still not pre-loaded enough. And a 3-axis DRO... I can't possibly afford that for the foreseeable future, but I have a hare-brained idea that does not involve digital calipers...
Dean, thanks! - I'm happy to know that others do it as well ;D.
Thank you Jim. Rounding them over on the RT would work as well, but then I don't get the sharpish bottom edges without lots of setup and changing positions... I've been contemplating making a dedicated profile cutter for the "Elmer" bearing blocks; but I'm just plain too lazy :big:
Thanks Kevin. All the rounding over by hand; my little files are my friends ;D And after filing, a bit of effort with emery as well. Fortunately Tel gave me the hint about using oil on the sand paper; that works a treat if you're not scared of getting your fingers VERY dirty
Trout, thanks; I don't know about a masterpiece though... Wait till you see today's trials and tribulations :-[
Thanks Marv. I have the same idea about the slitting saws; All the ones I have (that is BOTH of them
) was bought with stacking them in mind, and my arbor made to accommodate that. I did not take the tooth count into consideration though :-[. On materials that does not clog up the teeth, stacking them works very well, but with the teeth not matching, aluminium clogs the tooth spaces up very quickly; no matter what I try to use as lubrication.
Well, today I made the cam ;D... TWICE
At least My RT did it's part properly ;D
To mount the workpiece, I had to have backing for it (NO WAYS am I going to mill into the RT!). A block of brown stuff left over from when I re-did my kitchen a while ago came in handy, and I clamped the brass plate to it, and then drilled some holes on the drill press. Some small holes for putting screws in to hold the center down as that would be completely separated from the outside piece, as well as four mounting holes to bolt the lot to the RT and retain the outside ring in the process:
I've read some scathingly bad reviews of these cross-slide vises - and they are not great, but mine is invaluable on the drill press!
Can anybody spot the error yet?
The only way I could mount and clamp this lot on the RT was to have it offset at 45 degrees so I could line up the bigger (7mm to leave room for adjusting on 6mm bolts) holes I drilled with the T-slots on the table. I think my RT is too small... With the offset, the entire set of calculations was worthless, so I had a couple of choices - 1. Add the offset to the calculations in the spreadsheet and re-print the page. 2. Physically turn the RT base to 45 degrees on the mill table to eliminate the offset. 3 - and what I did; save a tree by not printing another page, and put temporary degree markings on the RT table with a marker pen - no need to offset the RT base. The RT was already clamped, and I had centered it properly to the mill spindle; Y was locked down, and my "DRO" was reset to zero as well. So I set the workpiece on center as accurately as possible using a 1mm center drill as reference - I really need to find (or make) a wiggler set for these operations!. With the workpiece properly (or so I thought) centered, I cranked X out to check on the square line for "rotational" alignment; pretty close, so I rotated the RT the necessary amount to get it spot on, and set the adjustable collar to zero on the RT. Good to go:
What?, you didn't spot the mistake yet ? - Neither did I!
I decided to use a new 6mm multi-flute end mill to cut the cam. 6mm, as that is what the engine's rollers will be (instead of 1/4"). Multi-flute, as I have discovered that these make MUCH nicer cuts than 2-flute. If you look at the bearing blocks in an earlier post, you'll see the difference in finish between the rectangular cut-outs on the thin and thick bearing blocks. The thin one was done with a 2-flute slot mill, and I had to do a lot of filing to clean it up. The thick one was done with the multi-flute (4mm in that case) as my 2-flute 4mm was too short to do the job. Surprise! - It did a much nicer job. My multi-flutes are not center cutting, so I needed a starter hole, which I just drilled with a 6mm drill, but at a 0.5 mm closer "radius" setting than the milling cutter would take - to give the milling cutter it's center clearance. Then I started cutting; 2 degree turn on the RT, and the reading from the table dialed in on X, and feed Z. Repeat. Repeat another 43 times. 1/4 way there and I took a smoke break:
Something seemed odd, but I just could not place my finger on it though... - I was in "feed the angle, turn the X, feed Z mode. Lots of readings to keep track of; "nothing will distract me..." (well, except a smoke break :big
Once I finished the the entire 360 degree circle; that is 180 Z cuts with X adjusted on each, JOY ;D - I'm done ;D ;D. Not a single mis-feed or ****oo ;D:
Stand back and admire a bit ;D.....
oh:
oh: :wall: :fan: - Yup; it hit me... When I set up the workpiece, I used the cam outer ring center instead of the bearing axis center to align the workpiece :-[ RATS, DRAT, DARN, WTFWYT... My brass plate is valuable (not only because of price; it's VERY hard to find.
I had a couple of ideas on making a rescue, but none would suffice, so I started again, and finished the job properly (I hope!):
I trimmed most of the excess off the cam ring (some bandsawing), and filed it down roughly to size based on the lines I scribed for the outside profile. The cusps left from milling on the inside of the cam was also filed down lightly till they were all just about gone; some more work needed with emery to clean those up. Then I stopped for the day; I wanted the cam finished today, but, alas, that was not to be.
Shot of the roughly finished cam:
And an assembly shot:
You can see where the cam meets the base that some more filing is needed! At least, its starting to look like something... Some more work needed...
Regards, Arnold
