That's the problem I don't understand.At this point you have two single cylinder engines mounted on a common base plate. You have separate carburetors, separate ignitions, separate cams.
Hi Brian - A little off the actual topic, but what is Naptha gas and where do you get it? What are the advantages of using it?The fuel is Naptha gas, same as I use in all of my engines. I have a few more diagnostic tricks to do today to see what is wrong.
Is this what we used to call white gas? That is what I used to put in my Coleman stove and lantern.Naptha gas is a clear liquid that used to be burned in gas lanterns and other in house gas appliances. The big plus with Naptha is that it doesn't smell bad when burned. Ordinary pump gasoline stinks to high heaven when burned indoors.---Brian
in the USA we commonly call it coleman fuel found in the hunting/camping supply area in stores such as walmart. hope that helps. and yes i had the same question a few years ago myself. use it for the coleman lanterns and camping cook stoves alotHi Brian - A little off the actual topic, but what is Naptha gas and where do you get it? What are the advantages of using it?
