I managed a bit of time in the shop today
First off, I needed a way to cut the dovetail on the head. I priced some dovetail cutters locally here in Windhoek, and after recovering from the ridiculous prices wanted, I had an option - order from overseas for 1/5th of the price (and wait 6 weeks for delivery) or make my own.
It was worth a try to make my own - so I thought a bit. I could have gone for HSS and spent a lot of time trying to grind an accurate cutter... OR - I could get back to basics and do it the really old fashioned way - with silver steel. I've made a fair lot of silver steel (drill rod) bits and cutters, but have never tried to use them on steel; well, there's a first time for everything.
My biggest piece of silver steel rod is 20mm in diameter; slightly too small to make a cutter as-is, but I had a plan. This is what I started with:
I mounted the rod in the 4-jaw, and offset it so that I could get a shaft diameter of 12mm with an 8mm "lobe" projecting when turned down a bit:
With the tailstock set over to 30 degrees (I decided on a 60 degree dovetail), I turned the lot down. Here, its part-way; you can see the lobe forming:
Once the shank part got down to 12mm, I finished off the taper on the lobe as smoothly as I could, and also turned a light undercut towards the center of the face on the end - this is for chip clearance at the bottom when in use.
Then I removed the lot from the lathe - chuck-and-all, and mounted it on the rotary table on the mill and whittled away half the lobe to get the cutter form done:
Removed from the chuck, I sawed the eccentric part that was gripped in the chuck off, then heated the cutting bit red-hot and quenched in oil to harden up the bit. A test with a file showed the shank part not completely hardened, but the cutting face was good and hard, so I had a very hard cutting edge and a slightly softer core on the bit. Because of this, I decided not to temper it - I just used a couple of strokes on an oilstone to hone up the cutting edges. This is what the cutter turned out like:
Poor photo; the light gray parts on the cutter was actually shiny from the honing. The light gray rectangle on the bottom is where I stoned in the bottom relief, and the light gray on the face is honed for the cutting edges.
Would it work ??? - the first cut; slow speed (150RPM), slow feed, and LOTS of cutting oil - and the first pass was done - and seemed to work well:
I'm a fan of Asterix... - in the books the authors (translators actually for the English books) always say "A little while later" for a journey that would have taken days (or weeks)... - but in my case, "A little while later" - in hours:
It was slow going; I didn't want to push the cutting bit too hard (heat is enemy #1 to silver steel!), and spent a lot of time squirting coolant on it. But it cut ;D - the dovetail itself has a very near mirror finish, though I'm a bit disappointed with the bottom finish I got; it could have been a lot smoother.
Overall, I'm happy though ;D - I had some time in the shop, made a single-point dovetail cutter from scratch, and cut my very first dovetail (at least part thereof!) on the mill. A good day ;D
Regards, Arnold
