#52 The picture above looks like an attempt at breeding rotary tables. Havin any luck? :big:
The picture below was staged after the fact. I forgot to take a picture and lightly re-chucked the part to shoot the picture. After 'picture guy' posted the pics I realized I forgot to re-install a rectangular saw cut backing piece that was used between the work piece and the face of the chuck to assure that the work piece wouldn't shift backwards during the drilling and subsequent boring of the clearance opening for the crankshaft.
My new 4-jaw chuck worked flawlessly, and proved to be a wise addition for my lathe. I'm so glad I mustered up the courage to buy, and learn how to use one. Its hard for me to believe how simple it is to dial in a work piece to within a few tenths.
#53 After boring out the crank shaft opening, the out side profile was cut at a 45 degree angle. I like to alter plans to suit my taste, and the elimination of the curved profile was planed before I started this build. All that's left to do on the 'column' is to mill out the 1/8" slot for the 'Lever'.
#54 I assembled the three structural pieces to see if every thing lines up, and all is well.
#55 The valve started out as a stock oversize (length wise) piece of square 1/4" brass bar. I milled out the opening for the 'Lever', and drilled the port holes first to simplify these steps while the valve material was still square.
#56 To turn the cylindrical parts of the 'Valve' my 4" chuck was installed. To remove the 6'' four jaw and replace it with the 4" took only two minutes. To dial in the workpiece within a 'tenth' took only a few more minutes. I still can't believe how easy this is, and I find the process relaxing and enjoyable.
A few years back I bought two of the indicator seen in the picture. At the start of my machining season back in November I looked at the tools in my collection and saw the cute little indicators in their fitted blue boxes. I thought to myself "why did I buy these", since I never had a use for them.
#57 After machining the two diameters I drilled the port hole from the threaded end to connect the two previously drilled cross port holes. I threaded the end for the 3/16" nut that was made up earlier along in the build. After checking all the measurements I parted off the 'valve'.
When I went to test fit it in the 'column' the ports didn't line up when the valve was pulled up against the stop nut! When it was pushed in against the square lever side, those ports lined up perfectly. After looking over the drawing under magnification it became apparent that the section I threaded was supposed to be cut- off, and the threaded section stopped at 1-7/32" and not the 1-5/16 dimension I followed in the lower drawing. The absence of the center drilled detail in the lower drawing threw me off! The fix was quick and simple. I reduced the diameter in the proposed area with a file, and carefully threaded for the nut to reach the 1-7/32" dimension. Then I cut off the excess threaded area with an Exacto Saw. It turned out well and left no evidence of the mishap. As they say, 'All is well that ends well."
In the picture below you can see that the nut is farther away from the port holes than the square section for the 'lever'. I didn't notice this until the pictures were uploaded earlier in the day. I went back down to the shop for the test fitting to see what the problem was, and fixed the problem with out any need to start all over again.
-MB
