#44 I didn't get much done. To much time was spent one choosing a chucks ,machining their back plates and cleaning up the mess along with a few other time consuming odds and ends.
I drilled the face ports on the 'column' using the drilling 'jig' provided in Elmer's plans. After spotting with the 1/16" drill, the 'jig' was removed to allow an easier escape for the chips. This method allows for a simple but precise way of locating the ports.
#45 To speed up the milling of the first two steps on the 'column', I cut out the excess with my band saw. Milling all of it out would have taken longer, and left an avalanche of aluminum chips to clean up.
#46 The final milling of the lower end of the 'column' will be done later and after the opening for the crankshaft is bored out.
#47 I prepared the 'column' for mounting in a four jaw chuck by placing tape where the face of the jaws will touch, and by gluing (spray adhesive) brass strips were the tips of the jaws will contact the workpiece tightly to hold it rigidly in place.
#48 The set-up below wouldn't work. The two side jaws contact each other on the first step of the jaws before contacting the work piece.
#49 The same set-up as the picture above, just a different camera angle to show the problem. Only two jaws are in contact with the work piece. It doesn't seem safe to proceed with the drilling and subsequent borring.
#50 By reversing three of the jaws to their inside configuration I was able to reach the work piece on all four sides. This leaves one jaw in its outside configuration.
#51 The picture below is the same set-up as picture #50, just a different camera angle.
I'm afraid to start boring out the opening by drilling a 1/2" starter hole.
With the face of only one jaw contacting the work piece (from behind) on a perpendicular plane to the spindle axis, There is a serious concern that the unsupported work piece could shift backwards.
I'm at a stand still with this set up and can't bring myself to start drilling.
-MB
