Ripcrow, I would be happy to do this calculation for you, but I require some additional information. (1) Is this an intercooled engine? (2) Is the 350 degree C exhaust temperature located upstream or downstream of the turbine wheel? (3) is this a 2 valve, or 4 valve head engine?
In the meantime, I will make some assumptions, and give you some numbers.
At sea level, on a 70 degree F day, air weighs about 0.07489 pounds per cubic foot. By compressing this air within a turbochargers compressor wheel (polytrophic compression) to 31 psig, it will increase the air temperature to 272.86 degrees F, with a resultant air density of 0.16838 pounds per cubic foot. Note: I am neglecting inefficiencies within the turbochargers compressor wheel. The actual air temperature will be warmer, however there will also be heat loss through the intake piping, and a whole lot of heat loss if theres intercooling. . . Which is why I need to know if theres intercooling on this engine.
A 16 liter 4-stroke engine at 1650 rpm will displace 7.7692 cubic feet per second. Ill assume a 2-valve head, with a pumping volumetric efficiency of 70% at 1650 rpm thus the engine is ingesting about 0.91572 pounds of air per second, at 1650 rpm.
The atmospheric air being sucked into the engine (14.7 psia at 70 degrees F) has an enthalpy of about 126.6 BTU per pound mass. The exhaust gas (350 degrees C, or 662 degrees F) will have an enthalpy of about 271.0 BTU per pound mass. Thus the net heat input into the exhaust gas is 144.4 BTU per pound mass. And with 0.91572 pounds of air per second flowing through the engine at 1650 rpm, you'll have 132.23 BTU per second entering the exhaust gas, or 476,030 BTU per hour entering the exhaust gas. This heat loss out the exhaust is equal to roughly 187 horsepower.
