I'm building Rudy Kouhoupt's walking-beam engine and I've hit a bit of a dilemma. I'm not sure what the clearance between the crankshaft and bronze bearings should be. I have Rudy's original article from Popular Mechanics 1969 (original pages from the magazine) and I also recently bought Working Steam Engines by Rudy Kouhoupt from village press since it included more detailed drawings on the engine.
The plans just state make the bronze bushings/bearings - bore 1/4", the eccentric, crank, and flywheel all say to ream 1/4". The crankshaft is also listed as 1/4". I reamed the bushings 1/4" without thinking. Obviously everything made at exactly 1/4" will probably not spin to well. Should I somehow hone these bushings out and use 1/4" shaft? What would a good clearance value be between the shaft and the bearings.
The shaft is another question - I have a piece of 1/4" drill rod, some 1/4" 416 stainless rod and some 1/4 12L14. I originally planned on using the 416 Stainless but its actually pretty rough finish and only about a 1/2 thou oversized. The more I think about it I should probably just use drill rod for shafting. In general what is the best material to use for shafts such as this?
This is my first engine, I started to build it once before when I was 14 or 15yrs old. I had found the original Popular Mechanics article in a bunch of articles my dad had saved in an old filing cabinet. Fast forward another 30 some years, I've resurrected the project - though I am starting over making it from brass and aluminum vs the steel I started with years ago.
My dad wanted me to be a machinist / mechanic way back (so I took a lot of tech courses back in high school) and had access to a lathe and drill press but never a mill. I chose computers as my career.. now I want to play machinist at night
