You're probably right Chuck, but the pictures I had suggested the type of valve I designed. I just can't imagine somebody trying to use one of these original Donkeys for a hoisting or logging operation and screwing a needle valve in and out. ;D ;D ;D Normally, I don't have any kind of control valve on my engines, I just plug in the air supply from my regulator and govern the speed with the regulator. This Donkey however is a bit of a different beast. For one, it is self starting. I have been asked to exhibit this engine, and it always shows a bit better if you can at least turn the air on and off with a valve/lever that was actually used on the original machinery. I don't really know whether or not I will actually be able to adjust the speed of the engine with this type of valve, but at least I should be able to turn the engine on and off with it. The only other time I made a valve similar to this one was on the carburetor of one of my gas engines, trying to use it as a throttle.---It didn't work worth a darn, seemed to either want to run wide open or not run at all.
