I am rather at an impasse right now. The engine has vastly improved compression after re-lapping the valves. I removed the Traxxas carburetor, because although the engine would fire and run for a short time, it wouldn't stay running, and I had no good way to tell if the carb was set too rich and was flooding the engine out. I went back to my vapour carb set-up, and now the engine fires consistently and happily when turned with the electric drill, but it still won't stay running when the drill is removed. This is the maddening time of engine building, when everything indicates that the engine should run, but it won't. I have advanced and retarded the ignition timing, but really, it works best at the 185 degrees from TDC just as Jan calls for in his plans. I know that the exhaust and intake cams are correctly positioned and they are built to Jans specifications. I have a few tricks up my sleeve yet. The gasoline I have been using is mixed at a 40:1 ratio with 2 stroke oil for my chainsaw, and is about 6 months old, so the volatiles in the fuel may not be what they should be. First thing today I will try it with new, unmixed fuel. The sparkplug does not protrude into the combustion chamber, but sets in a slight recess in the sparkplug hole. that didn't seem to make any difference with my other I.C. engines, but I may try and find a sparkplug with a longer nose to get the spark closer to the combustion chamber. I want to take a set of feeler gauges and check the clearance between the push-rods and the end of the valve stems. Those push-rods were a tad too long and were holding the valves open by a few thou, and when I shortened them to get some clearance to ensure that the valves closed all the way, I may have shortened them a bit too much. If all of that doesn't result in a running engine, I have one other trick left, but I don't want to resort to it. The engine was originally designed to have a 25mm bore. That is 0.984". I had a .875" reamer, so I built the engine with a 0.875" bore. I don't see how that could make any possible difference, but I am going to have a running engine here, come Hell or high water!!!
