Went out today and put a sizeable dent in the Rupnow fortune. Bought 15/16 and 31/32" Silver and Demmings drillbits, and a 1" reamer.---But I'm hesitant to use them. Methinks deep in my black little heart that there's something else going on here. I played some more with the engine tonight. Using transparent Tygon fuel line and the Traxxas carburator, it will suck fuel up the fuel line if I put my thumb over the carb air intake while turning the motor with my electric drill, but as soon as I take my thumb of the intake the fuel all runs back down the line into the tank. (Not the vapour tank, a different tank totally)) That shouldn't happen. The "tank" is about 1" below the carburetor. The fact that the fuel so readily runs back down the line means to me that there has to be an air leak somewhere between the carb body and the combustion chamber--(The fuel is running back under gravity--its not being blown back down the line.).When I do choke the engine, and it starts and runs but gradually slows and stops, I wonder if its actually running out of gas. The compression is good. Its not blowing back thru the carburetor like it would if the intake valve was leaking. There is only one bolted joint between the intake pipe and the cylinder head, but I have gasketed it and used gasket goo. Its almost impossible to quickly access the sparkplug and pull it out to check for fuel starvation or flooding. The vapour tank is a bit too "weird science" for me. If the engine is going to run, it should run on a carburetor. Once it runs on a carburetor, I'll try the vapour tank again.----And I did try some 20% nitro model aeroplane fuel tonight. Engine took right off and ran like a beast---for about 12 seconds, then laid down and died same as-same as.
