Today I hope to make my valves. There is a nifty trick associated with making valves that Chuck Fellows told me about 2 years ago, but this is the first time I've actually tried it. Valve stems for these small engines are quite small in diameter, while the head is roughly 3 times as large. This means that I will be turning 1/2" drill rod down to 4mm diameter by about 1 1/2" long. When you do this with the material supported only in the chuck, the small diameter begins to deflect away fom the cutting tool, and you end up with a tapered valve stem, which is something you definitly do not want. The secret to avoiding this is to turn down only 1/3 of the total length at a time to just above finished size, beginning at the end farthest from the chuck. Record your dial reading or set your cross slide stops, then turn down the next 1/3, and finally the last 1/3 closest to the chuck. This works most excellently, as I proved to myself yesterday while making the valve seat cutting tool. Once all 3 sections are turned to about .001-.002" oversized, then use some emery paper supported by a flat hacksaw blade to dress the stem down to finished size, It is a good idea to have something with a 4mm bore in it to keep test fitting as you do this to ensure that you don't turn or emery the shaft to an undersized condition, which is as bad or worse than a taper.
