Looking at it from a different direction: turn a bit of scrap wooden board or MDF in the lathe with a centre hole and a shoulder to fit inside the rim, and mount that on the rotary table, in place of the chuck.
I've went "Full Hillbilly" on the set up to drill the outer rim of the flywheel. Thanks to Charles Lamont of the U.K. for the idea. A piece of 3/4" plywood was turned to be a snug fit into the counterbore on one side of the flywheel rim. The plywood has a 3" hole cut in its center and is gripped by expanding the jaws of the chuck on the rotary table. A second piece of 3/4" plywood is attached from the other side with long screw-nails to hold the steel rim so it doesn't fall off while being drilled. There is a centerline scribed on the outer diameter of the rim. Even if the outer diameter and the hole in the plywood aren't perfectly concentric, it doesn't matter. What I'm after here is the correct number of degrees between holes drilled in the rim. As long as I pick up the centerline marked on the outer rim every 45 degrees, the holes will be in the right place, even if the plywood "orbits" a bit when I advance the rotary table. The holes in the hub are reamed for an exact fit of the 1/4" spokes, because I am using loctite between the spokes and the hub. The holes in the outer rim will be drilled 1/4" and not reamed. This gives me a better chance of getting the spokes exactly in place, and since they will be welded to the outer rim I can afford a bit more clearance for fit-up.
If you can get some left hand drills, sometimes the tap can be "unscrewed"Steamchick--I use a center cutting carbide end mill the same diameter as the tap drill to remove the broken tap.--OR --I use a larger endmill, cut a larger hole which includes the tap, mill to depth or all the way thru, then ream the hole and Loctite in an aluminum plug, then start over.
I have the Coles Corliss. I redesign LOTS of parts. Some are, IMNSHO, ridiculous in the way they are two parts instead of one. In your case, is the valve cast iron? This may be why there are two parts.Question for anyone who may have built this engine. The 3D model I downloaded has the valve shafts in two separate pieces keyed together with a mechanical tongue and groove. Why is this so? Why not combine those two separate pieces and make them a one piece unit?
Did the locktite drip down onto the faceplate and glue the hub to the plate or does it break free easily?
I can identify with the chips issue. I have to take off my shoes at the basement door and carry them across the kitchen floor to where my house shoes (aka slippers) are to keep the peace. A small price to pay since she does allow me the latitude and budget to pursue my interests.
I am working from a set of cad models that give the dimensional information, but not the material. I don't plan on using cast iron for the valves.
