If I put a separate spring to keep the intake valve closed at the end of the lever arm, I can then install a ramp to vary stroke. Once I do that, I'll disconnect the fuel line and watch how the juice is delivered. That clearing the charge is an important point and using porous disks ain't going to cut it. If I make a Venturi and spray fuel into it, it should help
Vol of gas needed for stoiciometric burn at 13:1 is 1.2 cu in. At stp for full stoke but were delivering at two bar for 50% of stroke so same as full volume at 1 bar
Assuming vapor volume is 1300x times liquid this is 0.015 cc of fuel !
My pump delivers 0.025 cc, almost double.
So if I halve the stroke, I should be ok.... Close but no cigar...
