- Oct 29, 2011
- 161
- 363
camshaft lobe ready
valve lifters shims
brass fitting on cam holders
valve lifters shims
and we are very close![]()
Hi
whats the yellow hose for? Looks like it´s going from the head to the carb?
Michael
Even in modern car engines they are using babbit bearings as the load is quite high at this location in the engine.
Mike
Use bronze instead brass, it will last much better. Brass is not solid as bronze. Make lubricating hole under the connecting rod where there is not pressure zone to be sure the bearing is well lubricated since you do not have oil canal inside the crankshaft to lubricate the connecting rod bearings and crank shaft bearings.
Mike, i am car mechanic and can tell you the babbit bearings is not longer in use in the modern car engines. Also we are using aluminium bearing alloys. The aluminium alloy bearing have wear resistance, high load-carrying capacity, fatigue strength, thermal conductivity, and excellent corrosion resistance, and low cost.
What is your ignition timing like? And what do you have for a flywheel? Sounds like it might be either to aggressive ignition and/or too little flywheel to keep it going.
Fake Chinese bearings perhaps?and we have the first failure .the bearing of the conecting rod is broken
i change it and try to start the engine again and the bearing again broke.i dont know the reason.now i have install brass bushes and i will see the results
