tarboxb
New Member
- May 13, 2014
- 3
- 0
Hello everyone. I am new here and on the home stretch on my BollAero 18 build. I still have the venturi assembly to construct but thought I would try to prime my engine and see if I could at least get it to fire a couple of times today. I was turning it over with a drill so I know that I had plenty of rpm. I was seeing bubbles coming out from the compression adjustment screw so I believe my contra piston is leaking. I just do not understand how this could be the case. My contra piston is quite tight and I feel that if it were much tighter, the compression would be unable to reset it. Does anyone have any suggestions on what I need to do to fix this problem? I appreciate everyone's help and am definitely hoping that I can get this thing running ASAP. Thanks a lot guys.
