plumbman23
- Jan 2, 2012
- 11
- 0
Hi all just a quick question what type of copper tube do you use for the boiler body?There seems to be confusion over what seems to be called "pluming copper" what ever that is..... I'm a plumber I should have heard of it lmao.ALL PLUMBING TUBE IS PURE COPPER.anyways in Canada we by the tube wholesale in lettered thickness M, L,and K(ACR tube and H also but that's for another time).All I would like to know is witch thickness most people here use. also there seems to be allot of concern about pressure inside.In north America the water pressure from the street or pump is usually around 60 psi (some exceptions) here in my town not uncommon on the job to see 90 psi in some houses.As long as you properly silver solder your joints the tube should hold no problem.So in my mind M thick should suffice altho I'm thinking of using L to be safe but experience teaches so better to ask than to be sorry (35 psi can kill that's why home hot water boilers in north America have a 30 psi relif valve)PSI cant be underrated.......
