- Jan 4, 2011
- 1,418
- 384
I have made a Bogstandard Paddleduck engine and it is giving me fits on getting the bottom crank section to turn freely. I have remade both the crank throws and the bearing blocks. I can put a drill rod through the bearing blocks and the rod turns freely. The throws turn freely until I tighten the clamping screw and then it binds up on half the rotation. Obviously the connecting shafts between the throws is cocking and no longer perpendicular to the throw. Anyone who has built this engine have any works of wisdom? I tried making the bearing block bore oversize but I still had the problem. Maybe I have to make the bore even bigger. Thoughts?
http://www.machinistblog.com/bogstandards-paddleduck-engine-plans/
