Black Widow V8 difficulty?
neil_1821
I’ve been wanting to build a V8 engine at some point along the way, although I’m currently in the middle of building a 5” Lion at the moment but there is an opportunity for me to buy the castings and drawings for the Black Widow V8.
I’ve been trying to do some research but there is very little out there and I’m wondering if anyone could post any pictures or their experience on how difficult it wound be to make? I initially thought I’d do the little demon V8 but after seeing a few videos on YouTube the black widow looks and sounds magnificent and I know there are very few casting kits still available.
I just recently purchased the castings and drawings for the Black Widow. It seems like there is some information missing. Curious if anyone has details on the distributer drive and rotor? Also looking for pushrod details and well as the lifters. I also don’t see any information on the water pump/oil pump pulleys and belt. I maybe too spoiled after working with the Little Demon plans.
I am in the same boat as you, I don't understand the plans or stuff is missing as you stated. M y trouble is in the same areas as you stated. If you come across easier to read (understand) plans, please forward a copy to me.....Steve
I am working on my own cad drawings. I am starting on the block here shortly and work on drawings for the missing items. I was given a phone number for one of the original designers and I have yet to call him. I have been too busy with my full time job. There are more in the same boat so maybe between us all we can get this completed. ....... Mark
Have you been able to do anything with this project yet?
My plan was to take the drawings and redo them in Fusion which I did start. I started with the block and than the heads and noticed that the combustion XO chambers do not line up with the cylinder bores per the drawings, so the heads need redone. The mount holes line up but not the combustion chambers. I did talk with Dwight and got the impression you makes things fit as you go. He got me in touch with another gentleman and he was going to look for the original drawings. So far no luck. This has been put on the back burner for now as I am busy with my full time job. I will keep plugging at it when I get time.
Mark
I machined one of the first castings sets approx 15 years ago when the only 'plans' were hand drawn and the dimensions were just a hint of what you needed to do. . It was a real seat of the pants project. . .just as has been posted on this thread.
I am now starting another one. . this time I managed to find some real CAD drawings but once again the dimensions of the individual parts don't seem to line up with other assemblies. . . You have to start with the block and double check all stated dimensions 2 to 3 times against the crank and head dimensions for fit .
This time I made a fixture to fit the crank bores so the block is perfectly vertical and horizontal to the axis of my mill. . . Then the block can have a final milling to the pan, head and intake surfaces too insure parallelism.
A typical problem is the main bearing web panels are not wide enough to allow machining to meet the crank bearing locations while keeping the bearings a proper distances. . seems to me this is where you have to alter the crank / block dimensions to fit the casting dimensions to the crank. . .
If nothing else the whole process is a great mental exercise
I would love to see the fixture if you care to share?
I don't advise this I am,the rights owner for the challenger all rights for the black widow are from this engine and were violated. Gary martian does not have the rights or the designer that goes back to 1966
Don't. This is to all Dwight Giles and ken Hurst did this.
It is not clear at all what you are saying in this post.
Gary Martin purchased the patterns and drawings for the "Black Widow V8" from Dwight Giles, who was in partnership with Ken Hurst.
Gary offers casting kits for the "Black Widow V8" with drawings on his website.
There was a "Challenger C-600" listed in the Coles catalog.
The topic of this thread seems to be the "Black Widow V8", and so are you saying people cannot come up with their own drawings for the Black Widow V8?
Are you also saying you own the copyrights to the "Black Widow V8"?
If the Challenger C-600 was sold by Coles, would that mean that Coles owns the copyright to the castings and drawings?
The Challenger C-600 and the Black Widow V8 don't look like the same engine.
The Black Widow appears to be an overhead valve engine, and the Challenger appears to be a flathead ?
How is it that "I am the rights owner for the Challenger, all rights for the Black Widow are from this engine" (the Challenger).
Can you explain this ? It is not clear at all.
Please clarify your statements so that we can understand exactly what you are taking issue with.
Thanks,
    239.3 KB
    403.4 KB
So the plans are wrong, the castings get made wrong because of this, and you are saying nobody is allowed to figure out how to make it right? Maybe you should exercise your rights to the plans by correcting them rather than telling others not to.
Well said Stan! The drawings are mine and they are trash but nobody is allowed to fix them? Expletive!!!!
Stan and George, it is not clear which engine and which set of drawings you guys are referring to.
The Black Widow and the Challenger are being discussed.
Are you guys referring to the "Black Widow V8" drawings ?
I don't think Gary Martin has any problems with someone making their own CAD drawings for the Black Widow V8.
I have the copy rights gary does not
A guy using the handle "Casted" has claims to have the rights to the Challenger and claims those rights are violated by the Black Widow. He then claimed "gary martian" doesn't have the rights to the Black Widow. A very odd claim from a guy with 4 posts total who came out of nowhere. The claim was not very clear and sort of rambled with punctuation in odd places, but I think he claims to own both, alleging the Black Widow as derivative work based on the challenger.
This guy has not responded for your initial request for clarification, but I think these are his claims. Who knows, could just be a troll.
Nope it's a life time mess. Next life time.i
I did and I am,not nice people here I see. Lol
So I guess some explanation is needed about why that does not give Gary Martin the copyright for the Black Widow.
I don't know how to resolve this with an unknown party "casted".
There is no way to even verify who this is, much less the copyright claim.
Please offer something to clarify the situation, other than just the statement "I own the Black Widow copyright".
