Dan Rowe
- Feb 12, 2010
- 594
- 18
JorgensenSteam said:I am assuming that the skewed gear can be cut using a simple indexing head, and the spiral gear needs a connection between the indexing head and the mill table feed?
Pat,
A straight tooth parallel depth bevel gear can be cut with the mill and an indexer. The skew version just makes the math and the set up a little harder.
Gears with curved teeth have to be geared or guided some way to get the curved tooth flank. Here is a brilliant method to make helical gears with the lathe:
http://www.homemodelenginemachinist.com/index.php?topic=9916.0
Gordy,
The site Ian linked says it requires the copyright permission to be obtained before uploading any material. It is not possible for the end user to know if this was actually done or not. The cost of the membership to the site is more than a new copy of the book so for me it was a no-brainer.
Dan
