Bending brass angle into a circle.
Great work.
So when did Chatham become remote? I thought "remote" was places like Big Trout Lake and Sachigo....
WELL DONE! - If it was easy I should have done that on my couple of vertical boilers. - Instead I use gravity.... but with care. (And a couple of little brackets).
Next time I may use a length of square bar rolled into a circle, then machined on the lathe to convert the square to angle... Cheating isn't a problem to me if results work out OK. And I like to make swarf...
I guess the base is a burner? - How do you ignite it?
The term fo this is bending the hard way. It applies to bending Chanel and bending flat stock on he widest side. I worked in s big metal welding shop where the machine bent 7” wide by 1” thick steel “ bar 180 deg to a given dimension across corners of the end of the bar. It had a series of heavy steel wheels with guide rails to prevent twisting . I don’t remember how much ower the motor that drove he hydraulic pump had but it was a lot. Therewere change wheels and guides for angle and Chanel. It must have come off a navy ship as it had a “US NAVY LETTERING sign on it. It didn’t even groan when bending the bars. A very scary machine to operate. The process actually created some heat in the bar. There was a chart that you bent to then checked and re bent as needed.when it had cooled. You could not guess at the correction as the bars did not always repeat due to residual stress in them.
I have some 1/2" x 1/2" x 1/8" brass angle I need to bend into a 6" circle, it will be silver soldered at the join. I have tried bending it around a form without much success It twists and the worst part is that the 90 degree angle decreases by several degrees, this is not good for what I need.
Does anyone have tips or ideas for me? Even if I could anneal it, I don't have a suitable amount of heat to do that, I think that the 90 degree angle will change.
I don't have the resources to build a roller which may or may not work.
Any ideas would be very appreciated.
Ray
How many do you need.
I have to make one part for rebuilding for a Antquic gauge from bar stock.
Thanks you for the offer but I was able to manufacture a ring out of angle. Not an easy job but it worked out just fine.
It mainly for one off.
I also did with aluminum if going paint.
On doors in Texas at Temple Beth. 18 foot diameter using ¾"× 6" flat bar. A set doors rolling in circle.
The small things was fun hobby work a lot more fun.
