G'Day All,
I thought that I would put my two bob's worth in here Re; homemade gear cutters. This method is
not my idea, & it works very well.
I stumbled on this site a few years ago (
www.metallmodellbau.de), while looking for ideas for homemade gear cutters. The article needed to be translated via Google translator for me to be able to read the more important parts of the text.
I found this method to be simple & very cost effective when considered to the price of gear milling cutters.
The multi tooth cutters have been turned & relieved from high carbon steel. Heat treated by using a gas flame & water quenched, then honed on the cutting surfaces. Important to note that the cutting face must be on the centreline of the blank.
The pitch of the teeth is calculated by multiplying the gear tooth module x pi, the included angle of the teeth is 40˚(for 20˚ pressure angle) & the depth calculated by multiplying the gear module x 2.25 + 0.05mm for 20˚ PA.
With the cutter held vertically, the centre of the cutter is centred on the dividing head height, the gear teeth are then cut to depth with several passes of the cutter. I used 4 cuts for a 1.5 module gear. As the cutter is cutting with several teeth at one time, an approximate involute form is cut via a numbers of small flats.
To further improve the profile of the teeth, I then made a simple jig & ran the gears together with 600 grit lapping paste in both directions until the work surface of the tooth looked OK.
I have used this method for a number of differing gear modules & all of the gears ran well in the required application with no excessive noise.
The two gears in the image are 0.6 module & were as test to try this method.
Don.
