- Dec 12, 2012
- 2,220
- 1,288
Norm you could if you wish make a backplate to fit the sieg with a Myford nose
Don't think it would be worth the effort.If going with my train of thought
then you can use the small lathe to make small items indoors in bad weather
One big advantage with the ER32 collet set is you can hold any size from 2mm to 20mm.I use it for holding threads without damage,and I have in mind
making and fitting a knurled alum ring,so I can close the collet by hand
I sometimes close the nut handtight for delicate items and with light cuts don't get slip.The beauty of this lathe is that it doesn't need bolting down and
you can pick it up and move it about
