Some progress on the Petter Apple top. Core box with register for correct alignment with the spark plug aperture. The core will sit vertically in the Drag ( bottom box )
I found that engine, it was in KansasCity, now in Arkansas.This is a 6HP (plated 5 1/2HP) Manatoba built engine not a 7HP
Not sure what airbrush you ordered but that sounds problematically thick from my experience. Guess you will find out soon enough. I would have gone for a mini HVLP 'touch up' gun. Even a cheapo knock off. Those have viscosity limits too, but that style of gun typically has a wider range needle/cap orifice combinations to try. You can typically dial that size of gun down to say 1.5" spray fan but its also a function of viscosity. Good luck. Cant wait to see some of these 3DP parts turn into metal, ultimately.I envision the thinned fastpatch as having the consistency of slightly thick latex paint.
Building the green twin engine build was brutal because I was trying to learn 3D modeling, 3D printing, was using a poor quality 3D printer, and my foundry work was learn-as-you-go.
This build is very focused, and based on 12 years of accumulated knowledge, so I am light years ahead of where I was on my last build, and that allows me to move much more quickly on this engine. I have the confidence on this build of knowing exactly what to do and how to do it, without the discouraging failures and blunders I experienced in the past.
The Prusa XL so far has been a very consistent machine, with no bed lifting, so that solves a lot of 3D printing problems, and allows steady progress.
I have not built an IC engine before, so there is a learning curve to that, but there are some really heavyweights in IC engine building on this forum, and with the knowledge that our members have here, I don't think there is any way for me to fail.
But you don't seem to know the various settings of the printer or ways to finish the prints . Moving so fast you are getting ahead of yourself and printing incomplete CAD designed parts etc
You are getting advice but tend to be ignoring quite a lot of it so there are likely to be failures along the way.
It is becoming a bit of a Brian thread. You may find that if you get to the building stage people will not feel like helping.
The contradictions don't help, one line you say you will set up outside to save REPEATED setting up. The next you are only talking of two casting sessions which is hardly a lot of repeats.
I have to inject here. When I start out on a new system that I do not know at all, I find MY work, indeed, IS random. but the randomness eventually bumps into something usefull then I start learning. Randomness takes longer and often interferes with smooth, linear learning, even so, it's the way I do things if I don't have a mentor/teacher/instruction book/etc.So much hand-wringing in this post.
But you don't seem to know the various settings of the printer or ways to finish the prints . Moving so fast you are getting ahead of yourself and printing incomplete CAD designed parts etc.
The default finest layer setting is working well enough to make usable patterns.
I tried the variable layer, and that did not work, so I will stick with the default finest layer setting, and add supports where necessary.
I am not getting ahead of myself, I just wanted to watch the printer run while I was working on work projects that day; it was never intended as a final print.
I do it my way in the end, but I do appreciate all the advice.
I know where the parting lines are; I don't need wrong information on that.
Brian does his own thing, for his own reasons, and while that may not be how other engine builders do things, Brian does not do this hobby to please others; he only has to please himself.
To give Brian credit, he did inspire me to purchase and learn Solidworks, and that has been a big thing for me.
Many thanks to Brian for paving the way on that with all his 3D models that he posted.
As I was learning 3D modeling, others were saying things like "Its just a pretty picture, but will never be of any use for anything".
So who has changed their tune these days? Lets be honest.
It is two casting sessions, but with multiple melts/pours.
For the green twin, I did five back-to-back pours in aluminum in about two hours, and so that was very efficient.
Otherwise that means five setups/takedowns, and over two days, 10 or more.
The only contradictions are the things you don't seem to quite understand completely.
I do everything for a reason and a purpose; there is nothing random.
You may not understand the reason and purpose, but that is ok.
I appreciate any help from anyone, with the understanding that it is my build, my way.
There is no quid pro quo here.
If you want to offer suggestions, I appreciate any and all suggestions.
I reserve the right to reject all suggestions for any reason, rational or irrational.
If need be, I will drive to Barney's house, and we will sit down next to his engine and figure out whatever we need to figure out, to make this engine work.
I would suggest you stop the hand wringing over every minute detail of this build, and remember that this is a hobby for me, and not a life and death situation as you seem to suggest.
I have this build under control.
Mistakes will be made.
They will be minor mistakes that can easily be corrected.
Feel free to comment as much as you want; all is appreciated, but if your can't handle the anxiety over how I do it, then comment on someone else's thread and save yourself from stroking out over how I am doing this one.
