I've been seeing a lot about glues and finishes that harden when exposed to UV. I wonder if there is any product there that might work for you? Enjoying the ride and looking forward to some metal casting!
It is possible that something like that could work.I've been seeing a lot about glues and finishes that harden when exposed to UV. I wonder if there is any product there that might work for you? Enjoying the ride and looking forward to some metal casting!
Dumb question but have you tried & dismissed a decent quality high build primer in a spray bomb? No gun, no mixing, no compressor, no cleanup. Just rattle & shoot. There are all kinds but if you go to an auto paint store you will have the best luck finding one that fills & flashes quickly for recoats. Even different colors/tones so you can use that to your advantage. I'm positive it is going to fill & sand better than any spackling compound, that's what its engineered to do. Think about the environment a typical car part or plastic based fender is going through its life. Especially compared to a water based spackle that is bound to have a hard time bonding on plastic. If you consider the tools used to spread patching compound, they are arguably a similar plastic as 3DP filament from this standpoint & are intended to be cleaned & re-used. Often you just have to bend it slightly & the dried spackle just lifts off.
The problem with activated CA glue or UV epoxy or anything like that is you are putting a rather uniform layer over the hills & valleys. So yes some is getting into the valleys which is 'fill' but its your job to sand & conform all the mountain tops. Because these glues cure hard (much harder than 3DP), that is making a lot of extra work to then sand & you are likely deviating from the base shape. CA can be purchased in a range of viscosities from water thin to honey thick but you have to essentially paint it on which is not so easy. Epoxy resins are typically thicker viscosity. Now you may want a hard shell for those reasons but sounds like you just want a good surface with minimum fuss & maximum turnaround time. IMO that is the domain of primers (or spot/glazing fillers if the grooves are deep enough to warrant).
The penmaking folks use CA glue to finish wood or other materials. Here is one I did. I was actually kind of amazed because I've always thought of it as just an adhesive. But it requires many layers & intermediary sanding. And the application is not exactly easy to get it on in a controlled manner.
