Here is some info I found on the Little Pumpjack Baker Monitor, and it says 320 lbs.
That is with one flywheel at 18" diameter.
So I suspect you are right about it being in the 200 lb range.
Not really tabletop material.
I will probably build a small frame with wheels to go under the base.
I really like an engine sitting on a base, with flywheels clear of the ground.
The floor space that a cart takes up is too much for what I have in my shop.
As I recall, you (JasonB) spun your frame in the lathe chuck, I guess to machine the bottom of the feet.
Myfordboy bolted the flat side of the cylinder to the lathe carriage, and used a bearing in the bottom of the crankcase, so he could line-bore his crankcase/cylinder. In this configuration, I think my frame/cylinder would fit on my 12"x36" Grizzly lathe.
(Photo my Myfordboy)
Another Ball Hopper Lone Star build shows the cylinder/frame bolted to what looks like a horizontall mill table, with the mill bit cantilevered out to bore the cylinder. I don't have a horizontal mill.
Here is a similar boring bar arrangement from the Southbend manual.
I think this is the way to do it.
For the bottom of the feet, I think I am going to remove the draft angle from the pattern halves, and cast the bottom of the feet flat.
Then I can just sand off the bottom of the feet, and use some bluing dye to level the feet exactly.
The crankshaft bearing will be poured with babbitt, and so the temporary shaft will be squared with the bore prior to pouring the bearings.
I am not sure about truing the top of the cylinder.
I will have to think about that one.
