You can clearly see the side-to-side grinding marks on the parting line in this photo.
It is to the left of your left-most arrow in your photo above.
I am not sure why the face of the coreprint would need to have draft angle, but I guess that could cause some breakout.
Does not matter on the end of the coreprint though if you have breakout, because that is not casting down there, but rather where the core meets the mold.
I guess we will find out about the lack of slope, but I have not used slope on the end of a coreprint before, but have not tried to cast something with such a large coreprint either.
With bound sand, the mold could actually end at the end of the coreprint, but it would be hard to do that with greensand.
The core is vented through the center, with both ends vented up and out the top of the mold.
I will probably use a large vent through the center of this core; perhaps 1 inch diameter.
The core needs to be lightly flamed to drive off any residual moisture.
I think some folks neglect to flame their cores, and also neglect to vent them out the top of the mold from both ends of the core..
Edit01:
As far as layout in the mold, I may cast the hopper upright, so I can gate into the bottom flange, and avoid having to grind in an area that won't be machined.
The knife gate would be shaped like a horsehoe, and would be entirely below the bottom flange.
A three-piece mold would allow this.
Edit02:
The nose of the green twin base was pretty flat, and it tended to break out the mold slightly, but it did not matter since there is a hole in the casting at the front of the base where a belt goes. A little breakout is ok if it is in a non-critical spot.
Edit03:
A strip of mylar would stop any breakouts on the end of the coreprints.
I plan on using a mylar strip around the flywheel rim, in order to get a perfectly flat rim right out of the mold.
Nothing worse than trying to grip a sloping surface in the lathe chuck.
Edit04:
If you did not want to keep up with mylar strips on the ends of the coreprint, you could use an automotive feeler gauge, a thin one but still stiff enough not to bend, and just run that down around the end of each coreprint. Pretty simple solution.
