Petit
Active Member
- Aug 18, 2013
- 36
- 21
Ok back from the dead it may seem! Cannot believe its been nearly 2 years since i started this project, where does the time go!? Anyway as you can probably guess i've had some lulls in productivity mainly due to motivation but also im building it at work so i can only work on it when time permits.
Anyway it is almost finished now and here are some progress pics:
Ok first thing, the propeller taper lock and washer was completed, purchased a propeller and stuck it all together:
Then i went on to make the carburettor components, hose tail, venturi body and gland nut
They were fun to make on a full size Colchester lathe but i got there!
Next was the carburettor body, i made this from aluminium round bar and machined the centre part square.
I then made the needle valve from 2mm steel rod, ran a thread up it and ground the needle untill i got a concentric point on the end. Put it all together and ended up with this:
The drawing called for a ptfe gland seal but it was impossible for me to make so i used sum suitable sized cable insulation which worked perfectly! :thumbup:
I did actually remake the carburettor body in the end as the wall thickness of the threaded part was way to thin.
