Fluffy
G'Day All,
Well, after a couple of years doing other things, the engine for the Aveling roller is finally finished & now the building of the rest of the roller is underway. The first problem here is that the materials for the chassis (25 x 16 channel, 10 x 10 angle as examples) are not available here in Oz., that I can find, so, these will need to be machined from solid bar stock.
The image below, is of the carburettor as it was made from a number of pieces & then silver brazed together & completed.
![DSCF4503.jpg DSCF4503.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43633-3d0468bb0ba6d458b26fc89de78dfb08.jpg)
![DSCN0402.jpg DSCN0402.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43634-a64b05af0f2f9e4dc4b33ea9babbed52.jpg)
The big end bearing, after final machining & then after hand scraping to fit the crank pin.
![DSCF4552.jpg DSCF4552.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43635-426dbe72790c30cdc3e9e1ffada5ba5a.jpg)
All of the engine components, manually machined, on completion.
Cam & ignition timing.
The completed engine.
![DSCF4624.jpg DSCF4624.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43639-c0faf63ec38dd51adac50c1c80eaa624.jpg)
![DSCF4629.jpg DSCF4629.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43640-1b3264f5c64ad70e0a34a6269522b920.jpg)
![DSCF4630.jpg DSCF4630.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43641-6db2f2e6c4d8e83d1534437161fde9e5.jpg)
After a few teething problems due to the incorrect material for the fixed ignition point (stainless steel) & replacing it with a tungsten carbide/brass point, the engine runs quite well, better than expected really & being a low compression engine, it revs considerably faster than I thought it would have been capable of achieving.
As soon as I can work out how to up load a video of the engine running I will do so.
Don.
![DSCF4573.jpg DSCF4573.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43636-84a5081cb4d84bddeadd08cd8ded3d2c.jpg)
![DSCF4610.jpg DSCF4610.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43637-b503020ae39d5f5fd8b95f2f5f4b6a4c.jpg)
![DSCF4619.jpg DSCF4619.jpg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attachments/43/43638-c6b80cbfb63ee6d22c17c2ad6833ded5.jpg)
Don.
