Arduino Rotary Table for Dummies
Yes, switches are very noisy, and unless "de-bounced," spurious key presses are pretty much inevitable. There are two approaches to debouncing, hardware or software. The hardware approach is to add a small capacitor between the signal and ground (try .001uF to .01uF or so) - this assumes a typical pull-up situation, either via a pull-up resistor or internal pull-up on the Arduino pins. The software approach is to implement a delay each time a key press is detected before reading any other key presses. Be sure that the delay does not interfere with the timing of the stepper routines.
I think I got it. My box has a big aluminum plate that the keypad and screen are mounted to. I ran a ground from it to the arduino and so far it's behaving.
I was wondering why no one else was having similar issues & this is probably why.
Mike
