Rod , I think it's cool that you make this software available for free . There are some issues with the nano , but I'll get to those later .
Stepper motors .
At first I had a beefier stepper in mind .
It fits the planetary gearbox , and it still , altough barely , clears the table when the dividing head
is tilted to 90°
This larger stepper however is a unipolair 6wire .
It can be driven by a bipolar driver if the centre wires not used .
The smaller stepper thatcame with the gearbox is an 8 wire motor .
Can be configured unipolar , bipolar series or bipolar parallel .
Each configuration has it's adavantages and disadvantages .
Unipolair is quite obsolete nowadays , it dates from back in the time when drivers and power transistors or fets were pretty expensive . It's the easiest and was the least expensive way to drive a motor , but it also has the least performance .
Bipolar series , and unipolar without using the centre wire , is used when a higher voltage is available , it needs less current then a bipolar parallel .Performance is better then unipoar , electronics are more complex .
Bipolar parallel can be used with less voltage but higher current .
If however a high voltage source is combined with a current controlled driver the torque and possible speed are at their highest levels . Best of both worlds in matter of speech . As both power supply and decent drivers are dirt cheap these days , the choice is easily made .
Bipolar parallel it is .
And then you have eight wires , without a clue wich is wich .
The connector is an ebay item so even if I had a datasheet that would be meaningless .
To figure it out all you really need is a couple of alligator clips .
First short any two wires and twist the motor shaft using thumb and index finger .
When you have shorted a pair , it will act as a brake and the shaft will be harder to twist .
Mark that pair or write down the colours .
Do this until you have found four pairs .
Next take any two pairs , wire them in parallel and short them .
The braking will be quite hard .
Reverse one of the pairs and short them again .Most likely that will have no effect .
That is not a matching pair . You have 12.5% chance of being right from the first time .
Repeat this with all of the pairs until you find a configuration where the braking effect goes away .
You have now found two matching pairs , and they are wired anti parallel .
Thus their magnetic fields work against each other and there is no or far less braking .
Thesame must be done with the other two pairs .
Does this make sense ?
It's easier done then trying to describe how to do it .
Once all wires determined I made a support for what round here is called an airplaine connector .
4 poles are needed , each pole has 2 wires soldered to it and heat shrink tube insulation .
I've made a little support for the connector and the wiring . Secures the wires , and makes it look good .
