maverick
Dale, Those heads look great. It's amazing how big the pile of parts is
for this build.
Mike
DTANNER said:I need to get that crankcase drawing from you did you send it this week end. I am in the shop atm and can start working on them if I can get another copy of it. I looked this morning and there was nothing there let me know which address that you are sending it to I may be looking at the wrong email.
Dan tanner
warranator said:I have question: Does the return crank and the crank line up when they fit together? Are the 2 shafts 4.17mm (return crank) and the 9.525mm (main crank shaft) supposed to be in line with each other when put together? If they are supposed to line up then I need to adjust the part so they match up as I don't think they do, I only looked by eye but it looks out.
No the slot is not at the perimeter of the 7.14 slot. This is what I was wondering. I could modify the bottom of the return crank slot radius so they both fit perfect.
