rac37
Active Member
Recently finished my build of the vertical ic engine designed by Brian Rupnow.
Thanks Brian.
Just strayed a little from the plans in a few areas.
-Went with brass cylinder with a steel liner just because I had a 2" piece on hand.
-Built the frame out of 3 pieces of aluminum since I did not have a big enough single piece on hand.
-Decided to make a cam drive for the intake instead of atmospheric type. Not for any particular reason.
-Gas tank from a plumbing fitting.
-Used hall sensor ignition since I had most components on hand.
-Carb from s/s machine.
Now hope I can get this video link to work.
https://youtu.be/iAWm3clr5pU
Thanks Brian.
