I did some measurements and discovered that I indeed have enough brass for both the top and bottom plates, so as of now the only material I am missing, AFAIK, is the correct diameter drill rod for the spool valves.
My first task this morning was to cut the ~6"x3" bottom plate blank out of a 9x4 piece of 1/4" brass. I could have done this on the bandsaw, but decided to mill it out with a 1/8" endmill. It took longer, but in the end I wasted less material. From the cutoff, I then cut out a piece big enough to turn the disc for the 4th crankweb. My boo-boo was to crank it a little too hard and broke the endmill. Luckily it's a double ended mill, so I still have one to go.
I was going to post in detail about another fubar I did, but I'll just summarize it by stating that when tapping a hole, look to see that you do indeed have the correct size tap in the tap wrench. :hammer:
After lunch I tackled the crankwebs, now that I had all 4 discs cut out. Drilled the holes and pressed in the drill rod. I am using 1/4" for both shaft and pin:
My little arbor press was handy here. Milled the first side:
I used a 3/8" ball-end mill to get the rounded inner corner. Then the other side:
All ready to be slit:
I'm not sure whether to drill and tap the lock screw before slitting.
