oldengineguy
Inspired by raveney's build of this engine using steel instead of pricy brass, I decided to have a go. As I do not have silver soldering equipment or skill, I am building the engine as a "bolt it together" I used 3/16 cold rolled for all parts of the crankcase so that screws could be counter sunk and epoxied over, and the inside caulked with JB Weld to seal it up. All fasteners are4-40 except cyl . to block which are 6-32. I made the cyl sleeves of cast iron and will make pistons of the same. The valve blocks are bolted to the cylinders. There is enough space between the valve bores to allow for a 4-40 screw to fasten parts together. Once the head is installed there should be sufficient strength. Lot's of hurdles ahead but hopefully I can work around any silver soldered parts . The crankcase and cylinder flanges are soft soldered. I have enough heat for that.
Onward! Colin
Onward! Colin
