I made changes to Randall's published design. Bigger crank discs, 4 1/2" vs 4". Different valve train allowing for hemispherical heads and 1/2" valves vs 3/8". Also I made two cams shafts which allowed more options re valve timing, duration, lift. In his original article Randall discussed opening the exhaust valve early to make the engine "bark". I decided to try this because most Harleys are loud. In fact, listening to one idle with a loud exhaust note, even at idle, I'm convinced that's what Harley has done to make their bikes extra loud. So I am opening the exhaust real early, while this must sacrifice some power it's only a model.
