ShedBoy said:
This engine is gong to look great Tim. Love the build pics
Brock
Thanks very much Brock
I've been itching to get back into the workshop for over a week now, but I believe that you can get tablets from the doctors to help with that :big: :big:
I also must give credit for the design and machining order of the crankdiscs to John (Bogs) :bow: :bow: as it is pretty much an exact copy from John's Paddleducks plans, just made a little smaller.
I got a couple of hours more in the workshop today, and carried on from where I left off in the previous post.
I reduced the brass bar down to 15mm diameter.
Then parted off four 4mm thick discs.
Then I chucked each of them in a 15mm er32 chuck and drilled a 3mm hole in the centre.
I could've just drilled them all before parting off, but the drill could well have deflected during the 25mm depth, and I really wanted to make sure that the holes would be central, so I drilled them all separately.
Then I made up a little jig to hold the crankdisc blanks in order to drill the crankpin holes all in exactly the same distance from the crankshaft centre.
It has to be the easiest jig to make, just drill a 2.9mm hole, press a short length of 3mm rod into the hole, then move the mill table over by 6mm ( half the stroke length ) and lock it in place. Then pop a crankdisc on it and then drill it with a 2mm bit.
Do that 3 more times, and then it is on to machining them into somewhat balanced cranks. I put a 3mm drillbit into the central holes and a 2mm rod into the 2mm holes :doh: then using some 0.5mm shims ( some feeler gauges ) to bring the 2mm rod up a tad. Press the whole lot down onto the vice and tighten.
Then I let loose with a 14mm endmill and nibbled down to what seemed to look ok, zeroing the DRO at the bottom cut. Then turn over and repeat.
Then it was a case of removing any burrs raised, then it was on to cutting the compression slot, this is done on each crankdisc individually, so I used a vice stop. Using the same shims and 3mm and 2mm rods to align before clamping. Then I aligned the slitting saw by eye.
Then I removed the rods and slitted the slot.
Stay tuned for more updates.
Tim
