- Jan 19, 2010
- 1,193
- 41
Upon tear-down and inspection of the TI4, I noticed something strange.
Once I took off the oil pan I felt the slop on the connecting rods. With the pistons at TDC and BDC there was some slop, but in the oposing direction there was none. This would indicate that the connecting rod journals have worn into an oval shape. I had brass bearings .003" thick in the rod ends, which were completely disintegrated and had turned into powder in the oil. This left the 60-61 aluminum connecting rod in direct contact with the the CRS crankshaft.
Tearing apart the engine further I removed the connecting rods and pistons, I then decided to measure the connecting rod journal bore in two places. All four connecting rod journals were no more that .00125 out of round, and still within the original spec I made them. This seemed strange since the slop in the connecting rod was at least .010" when the engine was together. So I then decided to measure the crank journals. They all indicated an out of round reading average of .006". WHAT, I thought, this cant be, the aluminum is stronger than the steel!! scratch.gif
Can anybody explain to me what is happening here? This just seems weird to me.
I have now reamed out the connecting rod journals, and using emery cloth have made the crank journals round again. There is now more space for a larger bronze bushing which is working great for the mains. I hope this solves the problem.
Kel
Kel
