10 or 12 inch is way too big. Bummer. No big deal I appreciate you taking the time to look. Thank you!!
Referring to post #15:
WHY was a 20 degree hole drilled into the head,/combustion chamber instead of a perpendicular hole, to locate the spark plug? Do spark plugs perform better when this hole is drilled at an angle? Would have a straight up spark plug worked just as well?
How much of a spark plug's electrode should protrude into the combustion chamber? What commercially available spark plug(s) would be a good choice for this application?
Referring to post #40:
Is there a rule of thumb that will help in determining how long a rocker arm should be....and where the pivot should be located? The pivot point will affect valve lift, breathing, etc. Did I read that lift should be 1/4 of the valve diameter? HELP!
When a rocker arm uses a roller, should the roller be hardened...be left at the same hardness as the valve stem...be softer than the valve stem? My gut tells me that replacing a worn out roller, would be far easier than replacing a valve because the stem tip got chewed up.
Referring to post # 46:
Lifter Guide Bushings....what's the best material for these bushings? Bearing Bronze....Oilite...Brass?
How strong/stiff should the valve springs be? I have no clue how you guys figure the spring specs.
Questions:
This may be obvious to some, but not to me....
How are the valve guides installed into the head? Are they just pressed in, so they could be removed in the future, for whatever reason? Are the intake and exhaust passages located and drilled first, then are the valve guides installed and drilled for the intake and exhaust passages? Are the intake/exhaust passages the same size in diameter?
Re: Spark plugs in aluminum heads....will they/can they seize? Can thread-seizing in aluminum become a problem?
Thanks,
Frank
Steve,
Do you have enough meat on the flywheel to cut teeth for the ring gear?
With the high cranking resistance, I have to ask: what is the compression
ratio?
