Been learning a lot on how to make these rings. Missed the note about anti-seize between each ring before annealing. Ended up welding a bunch together. Oh well. Process is slow. Cut more rings and will be polishing and annealing this weekend.
Lots of WD40 to make sure they dont start oxidizing.Finished rings that are ready for gapping. They will get cleaned and polished after gaps are setView attachment 135140View attachment 135141
"light test"??? please elaborate. Thank you.Nice work I remember I was dreading the rings but once I managed to find the right iron witch was not easy to get hear in Australia it really went very well ok I snapped a few and a few didn’t pass the light test but all in all not as hard as I was expecting
See Post #287 here: Ford 300 Inline Six"light test"??? please elaborate. Thank you.
Thank you!The light test is to install the ring in the cylinder and get it absolutely flat. Then shine a light up the cylinder and see if any light passes between the cylinder wall and the ring.
Great Thread! Wish I had seen it last month. I am going to use some of that information on my next batch of rings. Thanks for the link!See Post #287 here: Ford 300 Inline Six
How aere you installing these using a sleeve?I think I had problems too and ended up leaving a extra hole out and that worked for me , o heated up with oxy to a cherry red held it for probably? 10 seconds then let cool on the jig o and mainly had the heat on the jig as to get the hole lot hot , worked for me in the end but yes you will brake some o and biggest help is smallish batches of maybe 8 to 10 rings at a time incace it goes wrong
In view of the fact that we use chrome faced stainless steel ringsI will have to look at the drawings a little closer for that groove. I may have missed it. I suspect the 8 hour bake may be the problem causing the breakage. I made plenty of extras.
Sounds like you are doing another batch. Try the grey iron again but only bake for 3 hours at 1100F. I got that from a very smart guy very well educated in metal treating.
