OK finally I have some pictures.....
This is the front hub being bored before I reamed it with a short D-bit
Here the front hub is mounted on a mini face plate I used before with a 1/8" mandrel down the center. I reamed a hole in the piece of steel in the tailstock to the same size as the HSS mandrel. I then held the other end with this "center" while I fixed the front housing to the mini faceplate with superglue. Worked great and now the OD of the housing is dead concentric with the reamed hole.
Here I applied some heat and removed the housing from the faceplate.
Here I've mounted it in a collet and trimmed the housing to length.
